1. AC Question's Avatar
    Ok (I hope I am posting this to the correct place please tell me if I am not) I have screwed up my rooted Oneplus One by accidentally allowing it to update the system while rooted.
    Just now it is at the twrp recovery screen where I have (on the advice of a friend) using adb sidload put across cm12 in zip SuperSU zip xposedinstaller zip and xposed apk. However for each of the zips it went through fine on the computer but on my phone it would say MD5 file not found and would say failed at the top of the screen. After the sideload thing had completed and it gave me the option to reboot and I would try to reboot it would warn me that there was no OS installed.
    At this point I have no idea whether what i am doing is fixing my phone or not so any help and/or advice would be greatly appreciated
    07-29-2015 10:56 PM
  2. worldspy99's Avatar
    Might want to browse the forums over XDA as well.
    07-30-2015 12:00 AM
  1. Replies: 3
    Last Post: 08-02-2015, 02:32 PM
  2. Why cant i receive pictures on my cell phone
    Last Post: 07-30-2015, 12:28 PM
  3. Can't transfer photos from my android phone to computer
    Last Post: 07-29-2015, 10:41 PM
  4. Replies: 0
    Last Post: 07-29-2015, 10:36 PM
  5. Fix LG Tribute bootloop without wiping data (no backup)?
    Last Post: 07-29-2015, 09:55 PM
