1. Davidwoodd101's Avatar
    Zte grand max needs PUK Code to unlock sim
    07-31-2015 01:50 AM
  2. Oilfield Trash's Avatar
    Call your carrier, they will know the correct PUK Code.
    Sent from my SM-N900V using Tapatalk Pro
    07-31-2015 02:16 AM
  3. Davidwoodd101's Avatar
    Without contacting carrier
    07-31-2015 03:08 AM
  4. Javier P's Avatar
    PUK is a security unlock code for your SIM card. If there was an easy way to bypass it there wouldn't make much sense using it. If you have lost the original card frame, where it comes the PUK, the only other way is contacting your carrier with a proof that you're the owner of that account.
    belodion likes this.
    07-31-2015 07:30 AM
  1. My phone needs an PUK code to unlock the sim
    By DavidD1 in forum Ask a Question
    Last Post: 07-31-2015, 07:40 AM
  2. Replies: 0
    Last Post: 07-31-2015, 01:48 AM
