1. AC Question's Avatar
    My device is Lg L90 D410. Which is having lollipop 5.0.2. I tried to install twrp. After Flashing Device is not turning on. If i connect to laptop an 63.9MB disk is detecting. It doesn't enter download mode (or) Hard Reset.
    07-31-2015 10:22 AM
  2. srkmagnus's Avatar
    Is your device rooted and/or bootloader unlocked? If it is, make sure you follow the instructions to flash the TWRP specific to your device. If you install something not intended for your device there could be issues, i.e. a broken device.
    07-31-2015 12:03 PM
  1. Is Tmo's 700MHz LTE only for cellular data?
    By Eight Ball in forum T-Mobile
    Last Post: 08-21-2015, 05:21 PM
  2. Replies: 1
    Last Post: 07-31-2015, 12:13 PM
  3. Replies: 2
    Last Post: 07-31-2015, 12:07 PM
  4. Replies: 1
    Last Post: 07-31-2015, 10:22 AM
