1. AC Question's Avatar
    The upgrade loaded after stopping several times, but ever since it finished the icons are messed up, some double, some large, most don't work, and I can't remove any of them. There is a long lag in loading apps which wasn't the case before. The battery goes dead quickly. I've rebooted several times and did a 'clear cache' once (although it didn't take much time when it said it could take 15 min, so I don't know if it worked or not.
    Should I do a factory reset? Is there anything else to try first?
    Nancy
    07-31-2015 07:12 PM
  1. Broken screen on Galaxy s3, what are my options?
    Last Post: 08-01-2015, 11:52 PM
  2. What is the OS usage for?
    By Nitro211K in forum Samsung Galaxy Note 4
    Last Post: 07-31-2015, 08:51 PM
  3. Missing apps in app drawer on Droid Turbo
    By paleomjc in forum Android Apps
    Last Post: 07-31-2015, 06:52 PM
  4. Replies: 0
    Last Post: 07-31-2015, 06:49 PM
  5. S6 active questions [user upgrade from s4]
    By b00d9 in forum Samsung Galaxy S6 active
    Last Post: 07-31-2015, 06:22 PM
