1. AC Question's Avatar
    My phone turned off after reaching 0% battery life, I then went to charge it, left it only to come back and realise it was not turning on (it was a wall charger). After that I plugged it into my xbox 360 to charge it an the light turned red (constant, no flashing). I then proceeded to plug it into a computer (via multiple USB ports and cables) and it would connect to the computer as usual but then the computer didn't recognise the device. On one computer it came up with a code 43 and it is still not charging even though the computer knows there is something plugged into the USB port. Thanks in advance.
    08-01-2015 04:56 AM
  2. belodion's Avatar
    Welcome to AC.
    Perhaps the battery has failed?
    Read these guides by Rukbat:
    [GUIDE] Is My Battery Shot?
    [Guide] The Care and Feeding of Lithium Polymer Batteries
    08-01-2015 06:49 AM
  1. How can I downgrade my Galaxy Grand Prime from Kitkat 4.4.4?
    By AC Question in forum Samsung Galaxy Grand
    Last Post: 08-01-2015, 07:36 AM
  2. New galaxy note 2 with 4.1.2
    By Lensboy in forum Samsung Galaxy Note 2
    Last Post: 08-01-2015, 05:59 AM
  3. Replies: 1
    Last Post: 08-01-2015, 02:53 AM
  4. Replies: 0
    Last Post: 08-01-2015, 02:04 AM
  5. Can't download to Galaxy tablet from amazon app
    Last Post: 08-01-2015, 01:46 AM
