A AC Question Aug 1, 2015 #1 just wanted to know before il buy the wireless charging pad for s5, can be also used for s6?
Golfdriver97 Trusted Member Team Leader Moderator Dec 4, 2012 35,749 832 113 Aug 1, 2015 #2 Re: wireless charging pad for s5 is it compatible for charging s6? Welcome to the forums. I would think that it would work. If you are getting it from say, Amazon, it should be really easy to return if it doesn't. Upvote 0 Downvote
