1. AC Question's Avatar
    Just installed lollipop 5.0 on Note 3 in UK. It's official lollipop on unlocked untamed original Note 3.
    After initial upgrade it was a bit slow like volume up or down key would have some lag in playing the button sound and just general choppiness on screen.
    Did a factory reset and now is fast as butter lol.
    Now I'm not sure why the battery life was great one day and bad after a while. I've attached the 2 bystreet starts and basically it was doing great in dietary half but then after using the phone and going to sleep, just strong the 0w.08 mark you can see screen is off but the battery drain is really bad compared to the previous day. Also 4-5 APS have more battery usher than the screen.
    What app is doing this WiFi and awake usage when screen is off?
    htt p: //i57. tinypic. com/2qibxpy. jpg
    http: //i60. tinypic. com/35jl7js. jpg
    08-01-2015 11:32 PM
  1. Blocking lollipop OTA update
    By v8440 in forum Motorola Droid Turbo
    Last Post: 08-03-2015, 09:32 AM
  2. App Help
    By crazeecarroll in forum LG Optimus L
    Last Post: 08-03-2015, 01:44 AM
  3. ATT Note 4 random restarts since July 23rd update
    By Maisoumenos in forum Samsung Galaxy Note 4
    Last Post: 08-02-2015, 06:09 AM
  4. note 4 draining fast
    By pixieberry8 in forum Ask a Question
    Last Post: 08-01-2015, 11:30 PM
  5. Is the new Moto G 2015's battery is gonna last a day..??
    By Moto_Fan in forum Ask a Question
    Last Post: 08-01-2015, 10:12 PM
