1. 1Paptee's Avatar
    I got the s6 edge and to my amazement battery from fully charged dies in less than a day whether I touch the phone or NOT!
    I don't even have a sim card in it yet and I've turned of everything possible from ok Google to wifi searching while off to safe mode and still no improvement. I tried a factory reset and noticed data was wiped off alright but no interface to accept terms and conditions and language selection (like a new phone ) I need some help. Phone is decoded from sprint
    08-02-2015 09:26 AM
  2. Tavon Ray's Avatar
    You can download a app called 360 security and it will force close all app that are running in the background
    08-02-2015 11:12 AM
  3. 1Paptee's Avatar
    Thanks , I'll give it a try. Hope it helps...the thing is that I have not even registered on the app store no wifi no sim card...nothing. no additional apps besides wha came with the phone
    08-03-2015 04:05 AM
  1. s6 edge battery power pack
    By Tahertboy in forum Samsung Galaxy S6 edge
    Last Post: 08-10-2015, 01:39 AM
  2. turbo charger problems with USB 3.0
    By danielcee3 in forum Motorola Droid Turbo
    Last Post: 08-04-2015, 11:37 AM
  3. Why does my S5 and S6 disappear from find my mobile?
    By Manhanry in forum Samsung Galaxy S6
    Last Post: 08-02-2015, 09:38 AM
  4. How do I change the size of the icons on my S6 Edge?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 08-02-2015, 08:29 AM
  5. Samsung Galaxy S6: insufficient storage space
    Last Post: 08-02-2015, 05:36 AM
