1. AC Question's Avatar
    i have a Samsung S3 it keep shutting down while I'm browsing i check the battery was swollen so i replace the battery with a new and it's still shutting down
    08-03-2015 04:16 PM
  2. srkmagnus's Avatar
    It could still be the battery. Did you replace it with a new one or used? I'm assuming new...but still need to ask.
    I'd inquire about a replacement or purchase another. If still the same result then it's likely a hardware problem that may require the device to be replaced.
    08-03-2015 06:04 PM
  1. LG G4 This Phone is Garbage
    By Am100623 in forum LG G4
    Last Post: 03-05-2017, 02:39 PM
  2. How do I connect my Chromebook to my phone?
    By AC Question in forum Chromebooks
    Last Post: 02-12-2016, 07:21 PM
  3. Replies: 2
    Last Post: 08-06-2015, 08:06 AM
  4. Why won't my phone turn on?
    Last Post: 08-03-2015, 06:08 PM
  5. Replies: 1
    Last Post: 08-03-2015, 02:25 PM
