1. AC Question's Avatar
    My battery drains while my Nexus 5 phone is turned off. It will drain completely if I leave it powered off long enough. I have tried 3 manufacture resets and it continues to drain while powered off. Is this a software problem, battery problem or hardware (phone) problem?
    Many thanks in advance.
    08-04-2015 01:06 PM
  2. belodion's Avatar
    Welcome to AC.
    My guess is battery. See if you can get it tested.
    08-04-2015 01:10 PM
  3. raptir's Avatar
    LiIon batteries do lose charge over time naturally. You don't at all mention the kind of time frame you're talking about. Does it drain 5% per week? 20%? 100%?
    08-04-2015 02:09 PM
  4. Rukbat's Avatar
    It shouldn't drain much per week (in a few months, maybe, but not in one week). If it does, you could have a leaky capacitor on the motherboard (which normally means a new motherboard - most shops don't get into component-level replacement, because most people can't do it).
    Or, as belodion said, it could be a bad battery.
    08-04-2015 02:14 PM
  1. What are your expectations? (Screen, Battery, etc.)
    By Almeuit in forum Samsung Galaxy S6 edge+
    Last Post: 08-06-2015, 10:07 AM
  2. Replies: 1
    Last Post: 08-04-2015, 02:15 PM
  3. How do i remove zero launcher from my android?
    Last Post: 08-04-2015, 01:04 PM
  4. Why has my Android 4.4.2 browser stopped working?
    By AC Question in forum Android 4.4 KitKat
    Last Post: 08-04-2015, 12:55 PM
  5. Replies: 0
    Last Post: 08-04-2015, 12:51 PM
