1. AC Question's Avatar
    Looking at getting a new phone. I really like the note edge but scared it wont be supported down the road because verizon removed it off its site. Which one should i get?
    08-06-2015 01:40 PM
  2. Almeuit's Avatar
    That is a hard question to answer as phone choices are personal choices. Go with the one that you like the most / fit your needs.
    08-06-2015 01:51 PM
  3. ATLBRAVES12's Avatar
    do you think the note edge will get the updates on verizon?
    08-06-2015 05:50 PM
  1. Replies: 68
    Last Post: 02-17-2017, 01:01 PM
  2. Verizon note 4 stagefright patch?
    By Alex Wetzel in forum Samsung Galaxy Note 4
    Last Post: 08-12-2015, 05:46 PM
  3. Why can I not call or use the wifi on my Samsung Galaxy S4?
    Last Post: 08-06-2015, 01:36 PM
  4. Replies: 1
    Last Post: 08-06-2015, 12:49 PM
  5. Replies: 0
    Last Post: 08-06-2015, 11:54 AM
