1. 1Paptee's Avatar
    My s6 edge device used to be on sprint and I had it decoded. I noticed it doesn't really reset when I follow the factory reset instructions. It only kinda resets the date. All my pictures and music were still on the phone after I attempted to factory reset it. I also noticed after doing a factory reset the phone doesn't restart with the page to accept terms and conditions and choose language and all that. It just goes off. Phone is not rooted and hasn't been used. Alongside this problem is the very horrible cell standby drain. 68% !
    Will flashing the phone help ? Or will it reset the phone back to sprint? I need serious and concrete advice
    08-07-2015 01:42 AM
  2. famouzstarz#AC's Avatar
    what do you mean by decoded? i see your mentioning flash, if so it was probably rooted to achieve use on a different network thus not allowing for a factory reset because the use of a custom bootloader / recovery
    08-07-2015 11:46 AM
  1. GS5 factory reset on its own
    By Xterror in forum Samsung Galaxy S5
    Last Post: 08-07-2015, 07:54 PM
  2. Why am I not able to make or receive calls?
    By Justin Collins2 in forum HTC One Max
    Last Post: 08-07-2015, 05:28 PM
  3. Can I install android on my laptop(not tablet)?
    Last Post: 08-07-2015, 01:32 PM
  4. Why doesn't my Lenovo a5000 recognize my password anymore?
    By gedubraks in forum General Help and How To
    Last Post: 08-07-2015, 03:19 AM
  5. Not calculating steps
    By WynWins in forum Moto 360
    Last Post: 08-06-2015, 10:18 PM
