1. ajaymalik318's Avatar
    Except du battery save
    Sent from my AO5510 using Tapatalk
    08-08-2015 05:27 AM
  2. belodion's Avatar
    Welcome to Android Central.
    Probably Greenify.
    08-08-2015 06:12 AM
  3. Dirt bike Mike's Avatar
    Yeah the DU battery savor sucks I have the best luck with the CM products like CM cleaner and speed booster that has a antivirus it also has the CPU cooler it cleans up all the junk files and it boost your phone and then also there protection for locking device it's better I think too I think they're the best tool apps out there I got rid of all my DU products yesterday so I just wanted to give him a shot but they sucked and I went back to using all of the CM products they work way better
    Thank you from Mike Sears
    08-08-2015 07:05 AM
  1. Why does my S3 battery draining while it's charging?
    By vanessa_android in forum Samsung Galaxy S3
    Last Post: 08-08-2015, 06:15 AM
  2. How to root a acer iconia tablet model bi-750?
    Last Post: 08-08-2015, 04:59 AM
  3. Cannot remove chinese malware on rooted, CM 5.1.1, Verizon Galaxy S3 on straight talk
    By mellie815 in forum Verizon Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 08-08-2015, 04:24 AM
  4. Replies: 0
    Last Post: 08-08-2015, 04:10 AM
