1. AC Question's Avatar
    I am running Android 5.0.1 on a Samsung Galaxy Note 4 with Nova Launcher. I have asymmetrical hearing loss and am experimenting with adjusting the Sound Balance (L-R) differently when using earbud headsets without my hearing aid. Is there any way to create a shortcut (Home Screen icon) that would open the Sound Balance setting directly?
    Thanks,
    David Baril
    Almonte Ontario
    08-09-2015 09:01 AM
  2. Javier P's Avatar
    Hello David, welcome to the forums! I'm not sure if you can add such an specific shortcut. You could try this. Long press on your homescreen, select widgets, find "Activities" in the first row and drag it to the screen. There's an easy shortcut for the accessibility menu. If you scroll that list down you'll see about a hundred different options. Check if some of them (specially under settings) get you deeper in the accessibility menu. I don't have a Note so I can't check that for you, sorry. Tell us how it goes.
    08-09-2015 11:12 AM
  3. dpbaril's Avatar
    Thanks Javier. That saved me a couple of clicks. I was able to set up a shortcut to the Accessibility settings as you suggested, but could not find anything that linked to the Hearing/Sound Balance sub-settings directly. Thanks again.
    David Baril
    Almonte Ontario
    Javier P likes this.
    08-09-2015 04:30 PM
  4. Javier P's Avatar
    Glad it helped David! Thanks for registering and for the follow up. Yeah, after writing my last post I ran a quick search and found nothing else under Nova Activities. I'll let you know if something comes up. Welcome!
    08-09-2015 04:41 PM
  1. How can I disable wrong charger notification?
    Last Post: 08-09-2015, 06:11 PM
  2. How to do a factory reset when it has an unknown pattern lock
    Last Post: 08-09-2015, 06:10 PM
  3. How can I connect Micro SDXC to Nexus 9? Throubleshoot
    By Jack Hamm in forum Google Nexus 9
    Last Post: 08-09-2015, 12:05 PM
  4. How do I get delivery receipts for sent text messages?
    Last Post: 08-09-2015, 08:50 AM
  5. Why won't my Samsung A5 update to Lollipop.?
    By AC Question in forum Android 5.0 Lollipop
    Last Post: 08-09-2015, 08:01 AM
