1. TV help's Avatar
    I have a hisense smart TV, and a Galaxy S5 , I purchased the MHL adaptor and HDMI cable, I have it all hooked up but the HDMI cable doesn't fit in any of my holes in the TV..... am I missing a piece??
    08-10-2015 10:43 PM
  2. M-A Kuttner's Avatar
    Are you sure you have the correct HDMI cable types? As with most tech things, the "standard" of HDMI has 3 sub-types, none of which fits the other. Type "A" is the type you usually see, while Type "B" is a mini version. Type "C" is in-between the other 2 sizes. If it turns out the TV has an HDMI port of one of these other sizes, you'll need to get an adaptor cable.
    09-27-2015 11:36 PM
  1. Why do my phone ask for privacy pin when i try to reset it?
    Last Post: 09-28-2015, 06:53 AM
  2. how to update gaxay ace styles
    By im not a robot in forum Ask a Question
    Last Post: 09-28-2015, 06:14 AM
  3. Replies: 1
    Last Post: 09-28-2015, 02:52 AM
  4. Samsung Pay Updated (1.3.2116) IR Blaster Fixed
    By srz1977 in forum Samsung Pay
    Last Post: 09-27-2015, 11:56 PM
  5. How to hard reset/Factory reset iBall Andi Avonte5?
    Last Post: 09-27-2015, 10:25 PM
