A AC Question Aug 12, 2015 #1 I have the option of buying either a Global or US GSM version of an unlocked phone. Will the US GSM simply not work internationally or will the coverage just be better if I bought the Global GSM?
Almeuit Moderator Team Leader Moderator Apr 17, 2012 32,277 23 0 Visit site Aug 12, 2015 #2 GSM is mainly used outside the US so it should work. I would ensure you have the right plan though so you do not rack up a lot of charges. Upvote 0 Downvote
