1. AC Question's Avatar
    I upgraded to Lollipop 5.0 today and found that I had severe battery issues like what a lot of other people seemed to be experiencing. I tried factory resetting my phone and this didn't help the situation much at all. I decided to try and reinstall the previous running OS I had and that was Kit Kat 4.4.2. I followed a tutorial: Tutorial Downgrade Galaxy Note 3 from Lollipop 5.0 to Kitkat 4.4.2 Installing a fresh OS Fixing Bugs (i Technology Reviews) I can't post links..
    A while later after having pressed start I noticed a message saying the installation failed. With no cancel available I left my phone for a while to see if it'd stop on its own in Odin3 v3.07 and upon rebooting my phone I get to a screen saying:
    ODIN MODE
    PRODUCT NAME: SM-N9005
    CURRENT BINARYl: Samsun Official
    SYSTEM STATUS: Official
    REACTIVATION LOCK(KK): OFF
    KNOX KERNEL LOCK: 0X0
    KNOX WARRANTY VOID: 0X0
    QUALCOMM SECUREBOOT: ENABLE (CSB)
    RP SWREV: S2, T2, R2, A3, P3
    WRITE PROTECTION: Enable
    UDC START
    (In the middle of the screen)
    Firmware upgrade encountered an issue. Please select recovery mode in Kies & try again.
    __________________________________________________________________
    What do I do to fix this?
    08-15-2015 05:11 AM
  2. srkmagnus's Avatar
    Uninstall everything. Then re-install and re-download the appropriate firmware package for your device and see if that works. Keep us posted.
    08-15-2015 10:58 AM
  3. Japmayo's Avatar
    Hi there, (I made an account)
    I was able to install a polish version of kitkat 4.4.2 But now my network settings are no longer 2G,3G, and 4G but are LTE, WCDMA, and GSM, which from my quick googling appear to be the same just different names? (Please correct me if I'm wrong here).
    Thanks~
    08-15-2015 05:32 PM
  1. Replies: 10
    Last Post: 08-18-2015, 07:36 AM
  2. why does my cellphone show reload or try another page
    Last Post: 08-15-2015, 11:05 AM
  3. Replies: 0
    Last Post: 08-15-2015, 04:54 AM
  4. part 3 of brought 2 samsung galaxy tab s 10.5 week later back for repair
    By Shorne1 in forum Samsung Galaxy Tab S 10.5
    Last Post: 08-15-2015, 04:36 AM
  5. why does my cellphone show reload or try another page
    Last Post: 08-15-2015, 04:21 AM
