1. AC Question's Avatar
    use the Droid Turbo with Android i have been using the square reader and it works great but my issue is when i pull out the reader my ringer volume level is automatically set to low and i cannot turn it up unless i turn the phone off and restart it then everything is great. Ive used another droid turbo before and didn't have this issue. Also i thought the problem might be the case restricting full insert but that doesn't make any difference. Is this a phone issue?
    08-15-2015 09:28 AM
  2. Jeffsheri98's Avatar
    I have the same issue. I just got the Droid Turbo 2 a few weeks ago. And now when I use the square reader my ringer volume gets turned off and I can't turn it back on until I kill the square reader app. So I would also be interested if anyone has a solution to this.
    11-09-2015 10:28 PM
  1. Replies: 2
    Last Post: 08-20-2015, 10:55 AM
  2. How can I change the default SMS app?
    By Obi Huy Tran in forum Ask a Question
    Last Post: 08-17-2015, 07:58 AM
  3. Replies: 0
    Last Post: 08-15-2015, 09:16 AM
  4. Why does my LG G4 hotspot stop after a minute of use?
    Last Post: 08-15-2015, 08:32 AM
