1. Hammad Nawaz's Avatar
    Hi, its been a week that I am facing this issue!
    When i connect a charger to my phone, its showing it as its not increasing and stuck at 2% but when i check it (battery) using another phone its working fine,
    So it is clear that its not a issue of charger and battery
    now can anyone tell me whats the real problem with my mobile and how to recover it ?
    Using galaxy trend lite
    08-15-2015 12:37 PM
  2. belodion's Avatar
    Welcome to Android Central.
    There are various possibilities, but check that the USB lead is not faulty, and that the connector in the USB port is clean and undamaged.
    08-15-2015 05:52 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! I'm a bit confused--are you saying that when you move the battery from the first phone to a second phone, that second phone shows that the battery was charging up appropriately? Or do you mean that when you plug the same charger into a second phone, that second phone charges up normally?
    08-15-2015 06:11 PM
  1. My touch screen not responding, how do I fix it?
    By Damien Ramroop in forum General Help and How To
    Last Post: 08-15-2015, 05:57 PM
  2. How can I show message notifications on my Android 4.1.2(Verizon)?
    By AC Question in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 08-15-2015, 12:32 PM
  3. Replies: 0
    Last Post: 08-15-2015, 12:31 PM
  4. Replies: 0
    Last Post: 08-15-2015, 12:26 PM
