1. AC Question's Avatar
    Since i updated the new software in my note 3
    I'm getting lines of light on screen from right side of the screen
    It comes and goes but for more time the lines stays and for less time normal display screen
    P.S the phone didn't ask me to update software i by myself did it by going in settings and check for software update
    Now i don't know its because of update or the screen is damaged
    08-15-2015 12:37 PM
  2. belodion's Avatar
    It does sound like impending screen failure.
    08-15-2015 05:49 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Try taking a screenshot when you see the lines. Do the lines show up in the actual screenshot image? If so, then it might be some kind of software glitch. If not, then it's probably a screen hardware issue.
    08-15-2015 06:09 PM
  1. My touch screen not responding, how do I fix it?
    By Damien Ramroop in forum General Help and How To
    Last Post: 08-15-2015, 05:57 PM
  2. Replies: 5
    Last Post: 08-15-2015, 12:35 PM
  3. My phone is frozen on the lock screen, how can I fix it?
    By AC Question in forum Samsung Galaxy S3
    Last Post: 08-15-2015, 12:16 PM
  4. Cast Screen now enabled on Nexus 7 2012
    By Westernrider in forum Google Nexus 7 Tablet (2012)
    Last Post: 08-15-2015, 11:41 AM
  5. What does the U symbol at top left of the screen mean?
    Last Post: 08-15-2015, 11:36 AM
