1. KMM154's Avatar
    I have a problem on my otherwise lovely new Note 4. It does not play sound when I receive messages! My family and I have tried everything to get it working. Looked up known issues and found other Samsung Users have same problem on newer devices! Tried all suggested options to no avail! Can anyone help please? Checked all relevant sounds and apps etc are correctly set. Soft booted - still nothing grrrr!
    08-16-2015 07:37 AM
  2. srkmagnus's Avatar
    Go into system settings > sounds. Make sure the sound volumes are all the way up. Also, go into the messaging application > menu > settings > notifications. Make sure the app has an identified notification ringtone and that you have the notification option checked.
    08-16-2015 09:32 AM
  3. KMM154's Avatar
    Many thanks but I've done all that - still no sound.
    08-23-2015 12:23 PM
  1. Can't access folders in note edge
    By srgonu in forum Samsung Galaxy Note Edge
    Last Post: 08-17-2015, 02:28 AM
  2. Samsung Note 4 screen locked after Lollipop update
    By kvl7Z4 in forum Samsung Galaxy Note 4
    Last Post: 08-16-2015, 09:39 AM
  3. Replies: 1
    Last Post: 08-16-2015, 03:33 AM
  4. NEM Samsung keyboard cover for Note 4
    By googler003 in forum Samsung Galaxy Note 4
    Last Post: 08-16-2015, 12:39 AM
  5. How do I stop texts from going to draft messages?
    Last Post: 08-15-2015, 10:05 PM
