1. AC Question's Avatar
    When I try to charge I get a faint flashing green light. The screen does not turn on. If the battery is removed and I try to charge I get a bright green light (not flashing). Is the battery the problem?
    08-17-2015 10:50 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Sounds like it could be the battery. But that phone doesn't have a user-removable battery--had you removed it before? Perhaps some issue has developed with the power connection.
    08-17-2015 12:07 PM
  1. Help manually updating the PRL on Galaxy S2 SPH- D710
    By Dana Sutherland in forum General Help and How To
    Last Post: 08-17-2015, 02:23 PM
  2. Replies: 1
    Last Post: 08-17-2015, 12:17 PM
  3. Can I get some help with a Changing Email on Calendar Issue?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 08-17-2015, 10:05 AM
  4. Why does my Trend Plus charge but drains in a morning?
    By di1264 in forum General Help and How To
    Last Post: 08-17-2015, 10:02 AM
