1. AC Question's Avatar
    Some days it seems that the phone holds a charge all day really good. Then others it just drains out and I only called two people for about 15 min. Put it on the charger and then it still drains until 0%. It can.. sometimes take a whole day and night to charge. Other times when you put it on the charger it's at a 100% in just two hrs. What gives?
    08-18-2015 06:16 PM
  2. belodion's Avatar
    The charger, USB lead, USB port, or battery may be faulty. But I think that you ought to get the phone and battery checked....it may be unsafe to continue using like that.
    08-18-2015 06:26 PM
  3. Josiah23's Avatar
    Try changing the battery and or the charger.
    Sent from my SM-G900V using Tapatalk
    08-18-2015 10:27 PM
  1. What is my voicemail number?
    Last Post: 08-18-2015, 07:07 PM
  2. Replies: 0
    Last Post: 08-18-2015, 06:13 PM
  3. Replies: 0
    Last Post: 08-18-2015, 06:07 PM
  4. How to I transfer my contacts to my sd card?
    Last Post: 08-18-2015, 05:58 PM
  5. Wireless keyboard with pinch zoom for Android 5.1.1
    By Steiny69 in forum Accessories
