1. AC Question's Avatar
    It recently said SD card unavailable when trying to download all my other apps stopped working I tried factory resseting but didn't work
    08-27-2015 08:04 PM
  2. billbell52's Avatar
    I just solved a problem with mine. It is a new Samsung 64GB card. When I inserted it Android (Lollipop) formatted it and set it up. I had lots of problems getting data on it. I finally put it in my PC using an adapter and formatted it. I inserted it in my tablet and Android setup the folders. It appears that Android did not properly format it. I would recommend formatting it on a computer.
    08-27-2015 08:39 PM
  3. Rukbat's Avatar
    It should properly format on the phone. (Formatting it on the computer is what usually causes problems.) Check the card with SD Insight (it could be counterfeit), but be prepared to have to replace it soon (IOW, keep everything backed up on the computer).
    08-27-2015 11:46 PM
  1. Verizon FoxFi Mobile Hotspot no longer working
    By bladerealm124 in forum Samsung Galaxy Note 4
    Last Post: 11-24-2015, 03:56 PM
  2. Pictures on SD card look broken
    By robcassman in forum Ask a Question
    Last Post: 08-28-2015, 11:57 AM
  3. Replies: 2
    Last Post: 08-27-2015, 09:19 PM
  4. Replies: 2
    Last Post: 08-27-2015, 09:15 PM
  5. Why does my sd card not work it says unavailable?
    Last Post: 08-27-2015, 09:07 PM
