1. AC Question's Avatar
    Over night, my battery started draining.
    Normally, after a full charge, it shows that I have 18 hours of battery under low/medium use of internet (WiFi and 4G combined), but now all of a sudden it's 6 hours even if I uninstalled all the apps which are constantly syncing and turned off all notifications, and GPS.
    The phone is 8 months old, still covered by 2-year standard warranty.
    Should I use the warranty, or is this a normal wear/tear category thing?
    08-30-2015 12:58 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Assuming that the battery hasn't been abused (e.g., draining it to zero repeatedly), that's pretty abnormal behavior. This kind of thing can be due to an app that is malfunctioning. If you can catch the phone when the battery's draining, but hasn't drained completely, show us the following:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    08-30-2015 02:07 AM
  3. Andi Kilin's Avatar
    After reading from forums, i got the advice to reset my phone - so I did it, and now it appears to have gone back to normal (after a full charge it now says 12 hours when WiFi/Data is activated).
    I hope it stays this way, otherwise I will post screenshots as you asked.
    Thanks for fast reply, anyway.
    B. Diddy likes this.
    08-30-2015 01:28 PM
  4. B. Diddy's Avatar
    Glad you got a solution! In the future, you may want to try wiping the cache partition first, since that doesn't erase any personal data or wipe the apps off your phone: [GUIDE] Nexus 5 Recovery
    08-30-2015 05:30 PM
  5. Andi Kilin's Avatar
    i did try it forst, but it didnt help
    09-01-2015 02:18 AM
  1. T-Mobile LG G4 Updated!
    By AlwaysSmile in forum LG G4
    Last Post: 09-28-2015, 01:00 AM
  2. Replies: 3
    Last Post: 08-30-2015, 05:28 PM
  3. Replies: 1
    Last Post: 08-30-2015, 02:13 AM
  4. what app will be best for me for cantrolling
    Last Post: 08-30-2015, 02:08 AM
  5. Replies: 1
    Last Post: 08-30-2015, 12:22 AM
