1. nick9853's Avatar
    I've just got back from holiday and my s6 edge won't hook up to the three network. It worked fine in France but when I got to Dover and it should have gone back to 3, it just says cannot connect, try later,and emergency calls only. It works fine on wifi but even after a factory reset it still won't connect to my network. It was quite hot in France, but I tried to keep it out of direct sunlight. Any ideas please? It didn't have any errors on screen either.
    08-30-2015 09:25 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try Settings>Mobile Networks>Network Operators. Does that give you a list of available networks, and can you select Three there?
    08-31-2015 12:21 AM
  3. nick9853's Avatar
    Hi, it finds the networks but won't attach to any. Just says can't attach to network, try again later. I've tried again this morning with the same result
    08-31-2015 02:21 AM
  4. B. Diddy's Avatar
    Hmm. Try removing the SIM, then reinserting it.
    08-31-2015 11:16 AM
  5. nick9853's Avatar
    Tried that too, definitely not the sim card as it works fine in my daughters phone. I'll try Samsung and see what they say
    Cheers
    08-31-2015 11:19 AM
  6. ttteachhh's Avatar
    Did you fix it? I have the same problem now...
    12-09-2015 12:36 PM
  7. anon(632115)'s Avatar
    I guess he did as he has not been here since early September. I think you should start a new thread detailing your issue so we can help you get back up and running
    12-09-2015 02:18 PM
  1. Replies: 5
    Last Post: 02-21-2017, 09:30 PM
  2. I'm locked out of my GS6 Edge, how can I get back in?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 08-31-2015, 12:39 AM
  3. Replies: 1
    Last Post: 08-31-2015, 12:38 AM
  4. Where can I find my S Note Files?
    Last Post: 08-31-2015, 12:27 AM
