1. AllenRulz's Avatar
    So for the past couple months I have to now force the Micro USB to stay plugged in to charge my device. I've tried other cords and they simply don't work or stay. Idk if I somehow bent that little part in the phone where the cord goes or what but I don't know what to do anymore. I bought the phone outright from Google unlocked. Is there any tips to try or am I just screwed?
    I appreciate any kind of help.
    08-31-2015 11:49 AM
  2. B. Diddy's Avatar
    If every cable is like this, then it's probably the microUSB port that's damaged. Does it still work for data transfer?
    You'd probably need to get the port replaced. Or get a wireless charger and rely on that.
    AllenRulz likes this.
    08-31-2015 11:55 AM
  3. AllenRulz's Avatar
    Yeah my main cable works if I get it to stay in the right position. How do I get the port replaced?
    08-31-2015 12:06 PM
  4. B. Diddy's Avatar
    Take it to any good cellphone repair shop--that kind of repair should be relatively straightforward. You can probably find DIY videos on YouTube as well, if you're the handy type.
    08-31-2015 12:17 PM
  1. Why is my Xiaomi mi battery not charging?
    By AC Question in forum Batteries
    Last Post: 10-04-2016, 10:55 AM
  2. wireless charging and battery
    By Ricky Cox in forum Samsung Galaxy Note 5
    Last Post: 08-31-2015, 12:12 PM
  3. How do I put my LG Stylo in demo mode?
    By AC Question in forum LG
    Last Post: 08-31-2015, 12:06 PM
  4. Replies: 1
    Last Post: 08-31-2015, 12:02 PM
  5. Having issues charging battery
    By lozo0055 in forum Samsung Galaxy S6 edge
    Last Post: 08-31-2015, 11:23 AM
