1. AC Question's Avatar
    I have purchased a new ASUS C 100 Fliptop from the USA and am waiting delivery. I understand that the electricity supply is different in the UK? Will my device work in the UK? can anyone help please?
    09-02-2015 09:01 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Virtually every device's power adapter these days is compatible with 110V and 220V. When you get it, look at the power adapter, and see if it says 110-220V--that means you don't need a voltage converter. You will, however, need an adapter so that the plug can fit in the UK sockets (which should only cost a couple of dollars or so).
    09-02-2015 01:21 PM
  1. guys need help ASAP
    By John Francisco in forum Ask a Question
    Last Post: 09-04-2015, 07:15 PM
  2. How can I open the Play Store without an internet connection?
    By AC Question in forum Google Play Store
    Last Post: 09-02-2015, 01:46 PM
  3. Why wont my s6 turn on
    Last Post: 09-02-2015, 01:27 PM
  4. Move Apps To SD Card
    By addison99 in forum Acer Iconia One 8
    Last Post: 09-02-2015, 01:02 PM
  5. Replies: 0
    Last Post: 09-02-2015, 08:03 AM
