1. AC Question's Avatar
    Hey. Have tried to google a solution but cannot find one.
    I take my phone of the charger at 5.20 am and i need to charge it again at 4pm. The phone got around 10% if not dead yet.
    I switch the battery saving mode at 6 am.
    What drains the most is android OS(12%), Gmail(10%), google play services(9%) and screen(8%).
    anyone else having same issues or possibly any solutions to this kind of problem?
    09-03-2015 09:57 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    09-03-2015 01:01 PM
  3. eliasqt's Avatar
    May not contain everything you asked for, for instance standby.
    My phone isnt on english but i hope you know the icons. if not, i'll gladly translate for you.
    Active time om screen was 1.5 hours when brightness was om 45%.
    Thanks in advance
    Attached Thumbnails Why is my battery life bad on my s6 edge?-393.jpg   Why is my battery life bad on my s6 edge?-392.jpg
    09-04-2015 04:14 AM
  4. B. Diddy's Avatar
    You cell signal looks pretty bad in that screenshot. Tap the battery graph--do you get a fullscreen graph that includes a bar showing mobile signal strength?
    If not, install GSam Battery Monitor, which does show you that information.
    09-04-2015 01:10 PM
  1. Unable to use data while on a call
    By Calvin Fearrington in forum Samsung Galaxy S6 edge+
    Last Post: 09-26-2015, 09:47 AM
  2. Replies: 4
    Last Post: 09-03-2015, 04:49 PM
  3. Why doesn't Xfinity TV Go app not work with my Samsung S?
    Last Post: 09-03-2015, 01:03 PM
  4. Replies: 1
    Last Post: 09-03-2015, 09:58 AM
  5. Replies: 0
    Last Post: 09-03-2015, 09:30 AM
