1. AC Question's Avatar
    My internet connection on my Samsung Galaxy s4 shows that it is connected and strong - both at home and at work. However I cannot connect to the internet in either location. I get a message that says DNS_PROBE_FINISHED_NO_INTERNET. My laptop and other devices that connect to the WIFI are getting on the internet just fine. This problem just started this morning.
    09-03-2015 12:56 PM
  2. B. Diddy's Avatar
    Did you ask this already? I feel like I answered this earlier today, but I can't find it. Anyway, go to Settings>Wi-fi, long-press the network you're using, and Modify Network. Tap Advanced Setting, and make sure it's set to DHCP, not static IP. Does that work?
    09-03-2015 07:21 PM
  1. No longer Samsung Exclusive
    By SpookDroid in forum Samsung Gear S2
    Last Post: 09-10-2015, 07:03 AM
  2. Replies: 4
    Last Post: 09-03-2015, 05:38 PM
  3. How do I turn off accessibility shortcut on Samsung Galaxy Grand?
    By MillieBlack in forum General Help and How To
    Last Post: 09-03-2015, 12:54 PM
  4. Replies: 1
    Last Post: 09-03-2015, 12:39 PM
  5. Replies: 1
    Last Post: 09-03-2015, 12:16 PM
