1. AC Question's Avatar
    a red line flashes about 1 second when i go into internet; open new tab or go into any sites. I dont know what's wrong with it and i went to strict mode but it was already disabled. I haven't touched anything in particular... Please help me
    09-03-2015 05:38 PM
  2. belodion's Avatar
    Welcome to AC.
    Try a Cache Partition wipe.
    Tell us what that does.
    09-03-2015 06:02 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! That might be an Accessibility function--go to Settings>Accessibility and see if anything is turned on there. Alternatively, go to Settings>Developer Options, and see if anything is turned on there as well.
    09-03-2015 06:03 PM
  1. Replies: 11
    Last Post: 03-03-2017, 02:29 PM
  2. How do I separate out apps from the home screen folder?
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 09-03-2015, 06:12 PM
  3. How do you take the S6 Edge off retail mode?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 09-03-2015, 06:07 PM
  4. Replies: 1
    Last Post: 09-03-2015, 06:05 PM
