1. AC Question's Avatar
    I'm at work, I turn my volume down to vibrate. But then I get a blaring notification of an email. Turns out, you have to got to settings and turn down media volume, alarm volume, ring volume, notification volume, and any app volume in app all seperately. Then turn them all back up when I want to hear them again- How annoying!!!! Why can't I just turn the 'overall phone volume' down with one bar, what gives?
    09-04-2015 01:49 PM
  2. Rukbat's Avatar
    What gives is that Android has 4 sound systems, effectively. It's like turning the TV volume down, then wondering why the alarm clock rings so loud.
    There may be apps (I've never looked) that give you a single "all volumes" bar, or there may be a fast way to pop the 4-bar control up on that phone. Some ROMs do that automatically.
    Search the Play Store for volume control. https://play.google.com/store/apps/d...om.svk.avolume might be something you'd like (all 4 controls in a single widget you can keep on the homescreen).
    09-04-2015 08:05 PM
  3. stuntmonkeyok's Avatar
    The TV alarm clock isn't an accurate comparison, they're different sources for the sound. The phone is one device, one speaker; the problem I'm having(I'm OP) is like turning the volume off the TV but he commercials sounds still come through. It's a frustrating design flaw IMHO.
    09-15-2015 12:54 PM
  1. Whats up with my HTC One M8?
    By AC Question in forum HTC One M8
    Last Post: 09-04-2015, 06:24 PM
  2. Moto X Style/Moto X Pure Edition: Where is it manufactured?
    By jimlloyd40 in forum Moto X Pure Edition
    Last Post: 09-04-2015, 02:48 PM
  3. Why does my Droid Turbo go to a white screen?
    Last Post: 09-04-2015, 02:11 PM
  4. Replies: 1
    Last Post: 09-04-2015, 01:41 PM
  5. Where is S Planner and S Notes on my new Galaxy s5?
    Last Post: 09-04-2015, 01:30 PM
