1. AC Question's Avatar
    please can I have a bit of help with this issue. I have recently bought a Samsung S5 model number scl23 and the gps will not find my location. I've tried factory resetting the phone and just about gave myself a heart attack as I had to navigate my way through the first screen or two in Vietnamese. Running lollipop5.0 which is what the phone came with.
    Thanks for any help in advance
    09-07-2015 05:10 AM
  2. Bob Builder3's Avatar
    You will need to have mobile internet turned off for GPS to work properly. Try the GPS with your sim card out.
    The phone you received has been customed flashed to work in your country, seems like it is running a SphixV2a rom.
    10-17-2015 06:31 PM
  1. clips recorded with the tablet's camera - cannot be played
    By Petar Svacic in forum Samsung Galaxy Tab S 10.5
    Last Post: 09-29-2015, 04:54 AM
  2. Replies: 6
    Last Post: 09-07-2015, 05:54 PM
  3. GPS disappeared from device
    By JohnZipper in forum Samsung Galaxy Note 3
    Last Post: 09-07-2015, 01:49 AM
  4. Replies: 0
    Last Post: 09-06-2015, 09:41 PM
  5. Replies: 0
    Last Post: 09-06-2015, 08:11 PM
