Trouble connecting my HP 8 G2-1411 8-Inch 16 GB Tablet to my home's WiFi.
A
AC Question
It lists several options for connections, but when I connect (using the password # on my AT&T U-verse router) I get the "Authentication problem" Message. Is it because the signal strength isn't strong (in the basement). Also I'm not sure which # from my router to use. Do I use the Wireless Network Key, or the SN or the System Password #s.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,603
4,751
113
Welcome to Android Central! Who set up your router and wi-fi network? Do you know if your wi-fi network was set up with a password? The password on your router is probably if you want to log into its web interface to adjust the router settings, not the password to connect to your home network.
Non
