A
AC Question
It lists several options for connections, but when I connect (using the password # on my AT&T U-verse router) I get the "Authentication problem" Message. Is it because the signal strength isn't strong (in the basement). Also I'm not sure which # from my router to use. Do I use the Wireless Network Key, or the SN or the System Password #s.
