1. AC Question's Avatar
    So the WiFi on my Droid Turbo will not turn on. Background: Several weeks ago, I dropped my phone in the toilet. Thankfully, after drying out for a few days, the phone worked. However, I soon began to have problems with the WiFi not working. It would just turn off. I go into setting and try to turn WiFi back on, and it won't turn on. At first, it would occasionally turn on, work for a few days, before turning itself off and not working again. I have tried doing a hard reset on my phone with no luck.
    Any ideas for getting WiFi working again? I've had this phone less than a year and am not in a position to get a new one right now, but not having WiFi is making it nearly worthless to me.
    09-19-2015 10:50 AM
  2. dpham00's Avatar
    Have you tried a factory data reset?
    Sent from my Verizon Samsung Galaxy Note 5
    09-19-2015 11:01 AM
  3. wasnipes's Avatar
    Yes, I've done a hard reset and didn't get anywhere.
    09-19-2015 11:10 AM
  4. dpham00's Avatar
    It is probably water damaged then.
    If you have insurance, you can get it replaced
    You can buy a used one for around 250-300.
    09-19-2015 11:20 AM
  1. having to choose default app is there a work around
    By Christopher Gilliam in forum Samsung Galaxy Note 5
    Last Post: 09-19-2015, 01:20 PM
  2. How can I add my signature to texts
    Last Post: 09-19-2015, 12:00 PM
  3. Why the pictures album show all images?
    Last Post: 09-19-2015, 10:50 AM
  4. Replies: 0
  5. how to put Google play store game on sd card
    By Ben Smith15 in forum Ask a Question
    Last Post: 09-19-2015, 10:37 AM
