1. AC Question's Avatar
    Swipe down from the top of your screen to get the notification bar. At the top of the screen next to tr settings icon, you should see the 'edit' button. Click the 'edit' button to get the full quick settings such as wifi, Bluetooth, and others. Click on power saving mode and enable it. Then click on screen mirroring which is also on the quick settings panel and enable it. This will automatically disable power saving mode. Disable the screen mirroring after you've enabled it and then you're finished! Your touch key light will be off! If you ever want to enable it then just enable power saving mode then disable it.
    B. Diddy likes this.
    09-19-2015 05:47 PM
  2. B. Diddy's Avatar
    Welcome to Android Central, and thanks for the tip! Please consider registering on this forum, in case you have other good info to share.
    09-20-2015 03:12 AM
  1. Cannot activate google remote account manager
    By recDNA in forum Ask a Question
    Last Post: 09-26-2015, 08:49 AM
  2. S6 Edge connecting audio/media to GTR stereo
    By Rcox7576 in forum Samsung Galaxy S6 edge
    Last Post: 09-22-2015, 09:51 AM
  3. Replies: 1
    Last Post: 09-20-2015, 03:29 AM
  4. Replies: 0
    Last Post: 09-19-2015, 05:17 PM
  5. Replies: 0
    Last Post: 09-19-2015, 05:16 PM
