1. Tom_Pedecy's Avatar
    Quite often, when I unlock my phone it shows the lock screen for a split second and then lock again. I've read that its a problem with proximity sensor (on the left of the speaker).
    I have a tempered glass protector on screen, but there is no bubble above proximity sensor or any kind of dust. Everytime I stumble across this problem I try to clean the area and just spam lock button, after a while it goes away, but the knock knock unlocking still doesnt work. I have to reboot the phone for everything to work.
    09-20-2015 01:16 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Do you have a case with a smartcover as well? That can sometimes cause problems with the screen shutting off if you fold the cover behind the phone.
    09-20-2015 01:30 PM
  3. Tom_Pedecy's Avatar
    No, just a cheap sillicon case
    09-21-2015 11:14 AM
  4. redlinecoatings's Avatar
    Does your screen protector cover the sensor, or is there a cutout for it?
    Sent from my Nexus 6 using Tapatalk
    09-21-2015 12:50 PM
  5. Tom_Pedecy's Avatar
    It covers the sensor, but as i said there is no bubble or dirt above it.
    09-21-2015 02:19 PM
  6. B. Diddy's Avatar
    Could it have anything to do with the angle that light might be shining on the glass? Maybe I'm way off base, but perhaps if light shines at the right angle, glare might be created which essentially obscures the proximity sensor.
    09-21-2015 05:44 PM
  7. redlinecoatings's Avatar
    Try one with cutouts or try it with no protector. Any time I've had one that covered the sensor it was nothing but problems. It doesn't have to be dirty to mess with the sensor.
    B. Diddy likes this.
    09-21-2015 08:46 PM
  8. Tom_Pedecy's Avatar
    Okay, ill try without
    09-22-2015 02:09 AM
  9. Rumman Ashraf's Avatar
    @Tom_Pedecy Did it work ? also are you using marshemellow ?
    02-25-2016 07:25 PM
  1. Irulu AX101 stuck on Irulu connecting my world, how do I solve the problem?
    By haresh domadia in forum General Help and How To
    Last Post: 10-25-2015, 09:04 PM
  2. Lg G3 Full Signal but emergency call
    By PradeepKumar Kalyanasundaram in forum LG G3
    Last Post: 09-30-2015, 09:33 PM
  3. Brand new Sprint LG G pad 7.0 memory issue
    By Cinderela0629 in forum Ask a Question
    Last Post: 09-20-2015, 07:20 PM
  4. Lg g3/inserting larger sd/no pc
    By litchie in forum Ask a Question
    Last Post: 09-20-2015, 11:42 AM
  5. LG PRO 3?
    Last Post: 09-20-2015, 11:14 AM
