1. AC Question's Avatar
    A couple of days ago, my Nexus 7 suddenly started draining very quickly, and not fully charging overnight, even off. I have been through all the tests, cleared the cache, made sure there are no rouge programs... different chargers, cables on different wall sockets. Installed Ampere, and what I'm noting is, with the tablet sitting still, the charging amperage swings wildly, currently reporting 10 to 430 mA, but I've seen it go to negatives too. Verified on different cable/charger/wall socket. Is this normal? Anything else I can do to troubleshoot/fix?
    09-20-2015 07:11 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! 2012 or 2013? I'd guess that the battery is failing. You could consider trying to replace it.
    Laura Knotek likes this.
    09-20-2015 10:13 PM
  1. Replies: 4
    Last Post: 09-23-2015, 09:27 PM
  2. Replies: 1
    Last Post: 09-20-2015, 10:34 PM
  3. Nexus 7 - email and Play Store problems
    Last Post: 09-20-2015, 10:32 PM
  4. Back of phone gets hot when charging
    By Chitown28 in forum Samsung Galaxy Note 5
    Last Post: 09-20-2015, 06:14 PM
  5. Foxfi tethering - problems with using the proxy
    Last Post: 09-20-2015, 05:07 PM
