1. AC Question's Avatar
    I just got a galaxy s5 and can not figure out how to set my notification (not ringtone) sound to a custom sound. There does not appear to be a option in the notifications menu to ADD a sound like there is for ringtones. I tried to under contacts and it goes back to the same menu where I cant add one. I dont know how to copy from ringtones to notification sounds as was suggested in one forum.
    09-20-2015 07:28 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Check out this article: Android 101: Adding your own custom sounds to Android events | Android Central. Use any file manager app, or Windows Explorer, to copy the sound file to the Notifications directory on Internal Storage. Now when you select a notification tone, it should show up. If you don't see it, try rebooting first.
    09-20-2015 10:08 PM
  1. How do I get my gift card information on Android Pay
    Last Post: 09-20-2015, 10:15 PM
  2. Updates from laptop to S5
    Last Post: 09-20-2015, 07:48 PM
  3. Using my dad's upgrade?
    By Eclipse2K in forum Verizon
    Last Post: 09-20-2015, 07:18 PM
  4. Replies: 0
    Last Post: 09-20-2015, 06:01 PM
