1. AC Question's Avatar
    I just received my Galaxy S6 Active. It seems like the batter life is noticeably shorter than my S5. I suspect that applications are running in the background. Is there a way to close all or most of the applications by programming one of the buttons on the S6?
    09-23-2015 11:06 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! I wouldn't indiscriminately close apps, because the system will just reopen them--that's how Android works. It wants to keep RAM relatively full of open apps.
    It would be more useful to try to determine if any particular app or service is using excessive battery. Use something like GSam Battery Monitor to get a better idea.
    There are other reasons for battery drain as well. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    09-23-2015 11:34 AM
  1. S4. Just updated to lolipop phone keeps disconnecting wifi
    Last Post: 09-23-2015, 11:44 AM
  2. why do I lose so much battery power overnight
    Last Post: 09-23-2015, 11:42 AM
  3. How can I erase downloaded pictures from my Galaxy S5?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 09-23-2015, 11:38 AM
  4. How to sync gmail calendar on s5 galaxy
    Last Post: 09-23-2015, 11:09 AM
  5. Any way to filter contacts to only google?
    By cstrasz in forum Samsung Galaxy Note 5
    Last Post: 09-23-2015, 10:45 AM
