1. dharmikpatel's Avatar
    Ok so I have an HTC One M8. When I turn it on it'll stay on the android screen and won't load all the way (stays like that for hours). The only way to turn it on all the way is to do a factory reset from the bootloader. The only problem is when I do that it will load all way to home screen and a System UI error pops up.
    I called HTC and they said to download the ROM again. I tried it via USB and SD card and it doesn't work.
    Also if I turn it off after the factory reset, it'll go back to the first problem and won't load all the way unless I do a factory reset.
    At this point I have no idea why it work. FYI, the bootloader is unlocked.
    Does anyone know how to fix this problem?
    09-23-2015 12:03 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does a cache partition wipe do anything?
    09-23-2015 06:07 PM
  3. dharmikpatel's Avatar
    I haven't tried that. Actually didn't even think of it. I'll give it a try. Thank you!
    09-23-2015 07:48 PM
  1. OnePlus Two vs. Moto X Pure Edition
    By krazyatom in forum Phone Wars
    Last Post: 09-25-2015, 06:24 AM
  2. What is your telephone number?
    Last Post: 09-23-2015, 06:19 PM
  3. Replies: 1
    Last Post: 09-23-2015, 06:10 PM
  4. Why did my update make the smart cover stop working?
    Last Post: 09-23-2015, 06:08 PM
  5. How can I change my apps menu back to the way it was?
    Last Post: 09-23-2015, 01:18 PM
