1. AC Question's Avatar
    This just started happening recently. When I power the phone off, it just comes back on about 1-2 seconds after it has shut down. Even if I take out the battery, it powers back on when I insert the battery. Is there a setting I accidentally changed? Just pulled the battery between it shutting off and then back on again. Also took out the SIM. Left both out for about 5 mins then put them back in and it powered on right away. Now it has the Android guy on the screen and says "Downloading... Do not turn off target!!" also at the top left it says:
    Factory Mode
    Product Name: SGH-I337M
    Current Binary: Samsung Official
    System Status: Official
    Knox Kernel Lock: 0x0
    Knox Warranty Void: 0x0
    CSB-Config-LSB : 0x30 (the 'B's might be 8's... it's so tiny.)
    Secure Download: Enable
    WRITE PROTECTION: Enable
    eMMC (?) BURST MODE enabled
    It's just sitting there like that for quite a while now.
    Help!
    09-24-2015 08:58 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Press and hold the Power button for 10-15 seconds to force a shutdown. Wait a few seconds, then press and hold the Power button again until the phone turns on. Does it still go to Download Mode?
    MAcsSNAcs likes this.
    09-24-2015 12:25 PM
  3. MAcsSNAcs's Avatar
    I was able to do to that and get it out of download mode. Thanks. It's been suggested that the power button on the board will have to be replaced... any thoughts on that?
    09-24-2015 05:42 PM
  4. B. Diddy's Avatar
    If it keeps powering back on, then it's worth looking into. A qualified technician could probably determine if it needs to be replaced, but then again, they might just replace it (and charge you) and then see if the problem recurs.
    09-24-2015 06:11 PM
  1. Replies: 1
    Last Post: 09-24-2015, 02:15 PM
  2. samsung galaxy s3 not turning on
    Last Post: 09-24-2015, 02:13 PM
  3. Why can't I see my keypad?
    Last Post: 09-24-2015, 02:11 PM
  4. Unable to connect to WiFi on new phone
    Last Post: 09-24-2015, 02:10 PM
  5. Does not display call in progress unless in dialing screen
    Last Post: 09-24-2015, 12:30 PM
