1. AC Question's Avatar
    Hi there all from Greece! I have a Note 3 with android 5.0. I had never had any battery problem until some months ago when it started to go totally empty in about 3-4 hours of normal use. I thought that probably my original battery had some problem so i bought a new one. But something goes wrong with that one also. For example it lost around 5% while being locked and with only 3g on. In the battery settings top drains are almost always screen and android system. Any help?..
    09-24-2015 03:59 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Hope things are going ok over there.
    Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    09-24-2015 05:00 PM
  1. Replies: 2
    Last Post: 11-30-2015, 11:02 PM
  2. Note 2 Charging problem
    Last Post: 09-24-2015, 05:04 PM
  3. How do I sign in/log in to a facepage on my Samsung 4 phone
    Last Post: 09-24-2015, 05:01 PM
  4. Why did my keyboard move to top of screen?
  5. I need to pull pictures off of my lg flex
    Last Post: 09-24-2015, 04:18 PM
