1. AC Question's Avatar
    Okay, so I have had this phone for about a year, and recently for the past 2 weeks, it will go to about 2%, but whenever I turn it on, it will go to 0. And as soon as I unplug it, it dies. I thought it was the charger I was using, so I bought a new one, sadly, the new charger I bought did the same thing. If anyone knows the solution to my problem, please reply, thanks!
    09-24-2015 08:37 PM
  2. Raptor007's Avatar
    Sounds like the battery itself isn't holding a charge or very little. If you can replace the battery (not sealed in) try a new battery if it is sealed in (really dislike that) find out what the replacement cost is, but since its over a year old the factory warranty is up and so is any chance of free.
    09-24-2015 08:40 PM
  1. Replies: 5
    Last Post: 09-26-2015, 01:57 PM
  2. S3 battery not holding charge
    By Lorroth1 in forum AT&T Galaxy S III
    Last Post: 09-25-2015, 02:32 PM
  3. Possible VIRUS on my phone? - Galaxy S6 Edge
    By Heather K1 in forum Samsung Galaxy S6 edge
    Last Post: 09-25-2015, 11:54 AM
  4. How can I get my wifi to turn off?
    Last Post: 09-24-2015, 08:42 PM
  5. Replies: 0
    Last Post: 09-24-2015, 08:09 PM
