1. AC Question's Avatar
    Recently purchased kogan4g pro & genuine flip case
    When case is installed & closed the phone discharges in 4hrs.
    If the case is left opened or removed the phone will stay charged for days.
    I have contacted Kogan who sent a replacement case & same result
    I have tried changing a few settings & still no different.
    The case seams to be working OK in that it turns screen off & on automatically when opened or closed
    Any help would be appreciated.
    09-25-2015 02:53 AM
  2. baf1a's Avatar
    My Kogan 4gPro does the same. Seems the screen is turned on at times while the cover is closed. Would love to know of a fix.
    10-20-2015 07:44 PM
  3. baf1a's Avatar
    Attached felt protector pad approx 4mm thick inside along edge of cover and problem fixed. Thicker case though! Surely a better solution is available. Update to Android 5.1.1 didn't correct problem. There must be a sensor inside phone that reacts to magnet in case cover when case closed.
    11-17-2015 09:27 PM
  1. Why am i not getting lte on straighttalk?
    Last Post: 09-25-2015, 07:34 AM
  2. Replies: 0
    Last Post: 09-25-2015, 02:42 AM
  3. Why my phone is stuck in boot up loop ?
    Last Post: 09-25-2015, 02:41 AM
  4. my galaxy 4 mini has suddenly stopped accepting e mails
    Last Post: 09-25-2015, 02:37 AM
  5. Is It illegal to upgrade AT&T Phones Manually
    By Kaustubh Yadav in forum Samsung Galaxy S4
    Last Post: 09-25-2015, 02:35 AM
