1. AC Question's Avatar
    I have a Samsung Galaxy Note 1 GT N7000 which I gave to my son after I upgraded. The original battery wasn't charging so I bought a new battery. This battery had the same problem - charged 100% then tried to switch on but battery on 0% and couldn't switch on. So bought a third battery. Same problem.
    Is it something to do with the phone as the same thing happens with every battery I try?
    Thank you!
    09-26-2015 07:59 AM
  2. the tall guy's Avatar
    Hi, it sounds like an issue with the phone, almost as if it's not reading the battery correct. As the Note 1 is a rather old phone, it could also be down to age. Are you buying the batteries from the same retailer or have you tried buying a battery from someone else?
    Golfdriver97 likes this.
    09-26-2015 10:01 AM
  1. Thinking about buying LG3 or LG4
    By AmitM9S6 in forum LG G3
    Last Post: 10-05-2015, 11:06 AM
  2. Thinking about buying LG3 or LG4
    By AmitM9S6 in forum LG G4
    Last Post: 09-26-2015, 05:40 PM
  3. S6 edge+ battery life
    By AandriodYo in forum Samsung Galaxy S6 edge+
    Last Post: 09-26-2015, 07:06 AM
  4. Why I have only one ringing tone for all tasks??
    Last Post: 09-26-2015, 06:20 AM
  5. Why is my Samsung S3 not switching on?
    By AC Question in forum Samsung Galaxy S3
    Last Post: 09-26-2015, 05:36 AM
