1. S Nilges's Avatar
    Here is a screenshot of the battery status.
    09-27-2015 11:25 AM
  2. izzy67's Avatar
    What phone do you use?
    09-27-2015 11:26 AM
  3. S Nilges's Avatar
    Nexus 6.
    09-28-2015 02:53 PM
  4. GeeKraft HD's Avatar
    I notice facebook is really up there. Do you use it often? If you do, then it is pretty common that extended use of the facebook app can lead to battery drain since the application is pretty quirky. If you are using it rarely(probably not) then uninstall facebook immediately. In any case, I am highly recommending the Facebook Lite app on the Play store. It will use less power and less data.
    Sent from my Galaxy S5 using Tapatalk
    S Nilges likes this.
    09-28-2015 03:00 PM
  1. Analyze my battery life please?
    By JFeisty in forum Samsung Galaxy S6
    Last Post: 09-29-2015, 05:25 PM
  2. Concerning Battery Life & Heating up .. Z3 or HTC M8 ??
    By AC Question in forum HTC One M8
    Last Post: 09-27-2015, 06:23 PM
  3. Another battery question :P
    By Frozen Corpse in forum Samsung Galaxy Note 5
    Last Post: 09-27-2015, 11:55 AM
  4. Why does my Samsung S4 battery disconnect?
    By saifulislamgs in forum Samsung Galaxy S4
    Last Post: 09-27-2015, 07:54 AM
  5. Battery drain g s5 instantly
    By Aswath Raj in forum Samsung Galaxy S5
    Last Post: 09-27-2015, 12:45 AM
