1. AC Question's Avatar
    First my phone started draining the battery very quickly. Then it started shutting down as soon as I took a few of pictures. Soon after, it started shutting down after taking just one picture. Finally it started shutting down as soon as I turned the screen on. I thought the battery was dying quickly but when I plugged it in to the charger, it would stay on and the battery indicator said it was fully charged. But when I plugged it in, it would start "optimizing apps" every time I tried to plug it in to get it started again. It would take forever to optimize the 120 apps that it said I had. It wouldn't start at all unless I plugged it in and it would do the optimizing apps every time I did plug it. Finally it wouldn't stay on at all, even when plugged in. Every time I try to start it now, the Android logo comes on and it either begins optimizing apps again and then shuts down within a couple of seconds or it just shuts down as soon as the Android logo comes on. Please help!!
    09-28-2015 04:26 AM
  2. Javier P's Avatar
    Which phone do you have? Can you easily remove the battery? If so I could try with a new one and check if the problem persists.
    09-28-2015 08:05 AM
  1. how do i solve unfortunately, salesTrackerSystem has stoped?
    Last Post: 09-28-2015, 08:11 AM
  2. how to solve android core has stopped
    Last Post: 09-28-2015, 04:17 AM
  3. How can I turn on developers tool from my PC?
    Last Post: 09-28-2015, 04:09 AM
  4. Deleted the OS of my Cherry Mobile Cosmos Z2
    By tangskiyo in forum Ask a Question
    Last Post: 09-28-2015, 03:36 AM
  5. What does shell mean on my tablet I need the definition
    Last Post: 09-28-2015, 03:14 AM
