1. AC Question's Avatar
    is there a way to permanently switch to lte connection on galaxy tab s 10.5?
    09-28-2015 07:25 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Do you mean that you don't want 3G? Try going to Settings>Mobile Networks>Preferred Network Type ​(or something along those lines) and see if there's an option for LTE only.
    09-28-2015 11:11 PM
  3. bubbacola555's Avatar
    You can do as suggested by B.Diddy but if you are in an area that does not have LTE you will receive 4G, 3G or 2G and your carrier if has data limits will let you connect using LTE and then throttle you to 3G or 2G speeds. I have found that if throttled on LTE choosing 3G will sometimes be faster if carrier uses 3Gs play with settings and use Ookla speed test found on playstore
    09-29-2015 01:23 AM
  1. how to get USB tether to work on Note 5
    Last Post: 10-10-2015, 01:52 AM
  2. Note 4 on Groupon
    By rgh718 in forum Samsung Galaxy Note 4
    Last Post: 09-29-2015, 08:17 AM
  3. Can you add the Google Wallet card to Samsung Pay?
    By darnocs in forum Ask a Question
    Last Post: 09-28-2015, 06:44 PM
  4. Replies: 0
    Last Post: 09-28-2015, 06:32 PM
  5. Can I connect (and xfer files) between Galaxy S2 tablet and my PC ?
    By tabbingo in forum General Help and How To
    Last Post: 09-28-2015, 06:21 PM
